Results 1 to 8 of 8
Thread: rear right window weld broke...
    dublin, ca
    Default rear right window weld broke...
    Hey is there any way to fix or do i need a new actuator assembly? The motor works fine and the half moon geer turns jsut dosn't move window up and down.
    Hockinson, Washington
    Re-weld it?
    dublin, ca
    yah thats what im going to do it looks like someone had already tryd but dind't do a very good job. im going to do a beed all the way around now
    Im not sure how the piece of metal is shaped, but it might also work to rivet a reinforcing piece of metal on instead. The metal might be a kind that doesnt weld well.
    dublin, ca
    you know what i think i might jsut rivit it back together... I didn't even think of that!
    dublin, ca
    I just gave it a look and the lower theres not enough clearance to move window up and down riviting it.
    a picture is worth a thousand words...
    dublin, ca
    yah ill post some up... I welded it back together and itl never brake there again. Now theres a bushing im missing. Not the one that attaches to the window but it goes on the little nub that hookes up to the door. So I guess ill go to the stealership for that one.
  1. If you weld, read this, it may save your life
    By Ross in forum 5 Series BMW
    Last Post: 09-01-2009, 06:29 PM
  2. rear window will not go up?
    Last Post: 02-19-2009, 05:11 PM
  3. Broke a rear differential carrier bolt.
    By Martin in Bellevue in forum 5 Series BMW
    Last Post: 06-10-2007, 02:46 AM
  4. J.B. Weld and gasoline.. bad idea? OT
    By fujioko in forum 5 Series BMW
    Last Post: 06-02-2006, 09:49 PM
  5. rear window defogger
    By jeffgummy in forum 5 Series BMW
    Last Post: 09-21-2004, 11:01 PM
