Someone will probably ask you to fill out your profile with information on mileage...Originally Posted by nariusb
Hello everyone. I was just starting my trip and my auto transmission gave out. I heard a loud thump sound and now I have no forward at any speed. I used reverse to get back home. What Are my best options right now, rebuild, used, new??? Thanks for your input in advance. Or maybee it's a fix situation.
I have 1989 525i with m20 and 4hp-22 transmission.
deleted air conditioning
if reverse works its not the electrohydraulic clutch or the torque converter, probably the forward planetary gear shaft, which is one single part.
i would try to rebuild it before anything else.
Just to mention millage is 124k. When/if I replace planetary gear shaft, what else should be done? The compleat rebuild is very expensive here in Ontario, Canada? Maybee someone can suggest a good shop?Originally Posted by BillionPa
go for seals and clutch plates, as well as new filter.
well... i should mention that i have never seen the inside of your tranny.
It could also be the forward gear band, or even one of the gearsets.
if its the band that snapped, easy fix.
if its a gearset, new tranny.
new good used trans, saves bux and then you have the time to get the old one inspected and repaired, either save it as a spare or sell it.
I got my 4hp22 transmission brand new from Autosport Unlimited - $1400US in Chicago. I was told by my mechanic that this was cheap price.Originally Posted by nariusb
Please send me a private message for the phone number if you care to call them...
Put in a 5 speed![]()
I got a used tranny from www.car-part.com and the shop was out of Fortworth, Tx. It only set me back $425 US total and has a 90 day guarantee.
If you go used then you may want to ask what else you will need, like mounts or something that may break like exhaust nuts. I am not sure untill I do mine.
