Originally Posted by
joshua43214
So I started pulling interior parts out of my car so I could plan the installation of the stereo that formerly lived in my Saab.
After looking it over and talking to the Kicker tech people, I have decided to build a sub enclosure that will fit behind the backseat. The enclosure will span the entire back of the seat and be just as deep as needed to give the sub 1" clearance, then internaly blocked up to give the desired volume.
Mounting the amp is the next issue, the thing is rather large, 21"x12"x3" and weighs a fair amount. I can either mount it directly to the bottom of the parcel shelf upside down, or I can mount it to the back of the sub enclosure.
Inverted mounting gives me better access to the amps controls and wiring, but this stuff is not touched once the system is running properly so maybe not such a big deal. I just like the idea of the sub, amp and EQ all being in one nice clean assembly. Not to mention better heat disipation if its not inverted.
I like the idea of it mounting to the enclosure since I would not lose any vertical space that way, but it would put the bottom of the amp less than 2" from the magnet on the 10" sub. Is there a problem with an amp being so close to a large magnet like this? and is there any thing I can do to sheild it if so?
