View Poll Results: 10w40 or 20w50 in the Pacific Northwest?
Voters
6. You may not vote on this poll
  • 10w40
    3 50.00%
  • 20w50
    3 50.00%
Results 1 to 10 of 17
Thread: Royal Purple
    Seattle, Washington USA
    Default Royal Purple
    Hi all, I have been looking into going over to the Royal Purple Synthetic oil on my upcoming oil change. I am currently just running the standard 10w30 el-cheapo oil. My question is should I be using the 10w40, or the 20w50? Shes got lots of miles and a real prominent valve tapping that I will address as soon as I can get some time off work and a babysitter...
    Josh
    1990 BMW 525iA
    2000 Toyota Corolla CE
    2007 Toyota Echo
    Jul 2005
    NOR CAL
    thinner the better. allot of people run 0w40 mobile 1. id go with the 10w
    same here, royal purple makes some decent full synthetic dextron II for the automatic crowd that requires it.
    Jul 2005
    NOR CAL
    will that stuff work in manual gearboxes that require ATF???
    Wichita, KS
    0W-40 is recomended by BMW, Mobil 1 if you want to be specific.
    Eric, RP syncromax is recomended for manuals that require ATF. I put it in my 540/6, made a noticable difference in smoothness.
    Matt J.
    '95 540/6- Jim C. chip, Bilsteins, B&B, For Sale!
    -Sold
    www.wichitabmw.com
    USA
    in josh's car i would go with Redline 5W40 in the engine over royal purple due to superior anti-wear characteristics and low temperature flow.
    in addition, 40wt redline has a higher viscosity than 40wt royal purple at hot.
    and im my auto trans i am running a 50x50 mix of Redline D4 and B&M TrickShift synthetic, and its the smoothest transmission with the fastest lockup of any car i have driven.
    Hmmm, 5w40 Redline. I'll do some research on that... BTW, I'm an aggressive, high reeving driver...
    Josh
    1990 BMW 525iA
    2007 Toyota Echo
    Personally, I'd use Mobil 1. But, remember that the M20 was designed for regular dino oil, and that's what they've always gotten from dealers. There's no reason to spend extra money on more...exotic oils if the change intervals are kept something like regular.
    In the case of manual transmissions and ATF: I prefer the redline fluids, specifically MT-90. We almost exclusively use Royal Purple fluids -- synchromax and max gear are fine products, but if money isn't a concern, I'd still use redline stuff. I've run three different fluids through my trans in the past month: regular Dex III ATF, synchromax, and MT-90. The synchromax was the noisiest of the bunch, but shifted better than regular ATF. MT-90 is quieter than ATF and shifts better than synchromax once warm. Granted, this is on an old G260.6 -- I've never noticed more or less noise in using synchromax in any other transmission. Also, there's a SIB floating around that discusses the use of ATF in manual transmissions, and what fluids to use in response to a noise or shifting complaint.
    best, whit
    Very interesting information... My transmission shifts kinda hard between 1st and 2nd (automatic) but is fine the rest of the time... Is this normal or could it be fluid related? It shifts hard enough that if I lay on it she will peel out on the shift into second... Other than that shes soooooo smooth for 249,000 miles...
    Josh
    1990 BMW 525iA
    2007 Toyota Echo
    Maryland, Virginia, D.C.
    At what mileage did you change the transmission fluid? I'm hoping that you have.
  1. Purple Pride
    Last Post: 03-03-2008, 05:37 PM
  2. Replies: 8
    Last Post: 10-13-2006, 03:37 PM
  3. Purple M5 wagon in Ft. Lauderdale?
    By DanDombrowski in forum 5 Series BMW
    Last Post: 08-28-2005, 11:23 AM
  4. Anyone try Royal Purple tranny & diff fluids?
    By bfd in forum 5 Series BMW
    Last Post: 07-28-2005, 06:32 PM
  5. Replies: 10
    Last Post: 07-30-2004, 08:18 AM
