when did you change your air cabin filter?
When the A/C is on, there appears to be a loud rattling sound coming from the radiator/fan portion of the engine. I also get a burning smell when I floor it if the A/C is on.
Any ideas?
The sound is most likely be coming from the A/C clutch bearings, which is starting to seize up, hence dragging the A/C belt, causing the burning smell.
If the aux fan is bad or the system is overcharged it will also cause the belt to slip causing a burning smell.
Cabin air filter was changed 2 months ago.
Some hint: Check the compressor mounting,maybe loose or broken brackett.
While driving today with the temp set to cold (not A/C), it gave also off a burning smell for a few minutes.
What kind of burning smell? does it smell like burning wood or leaves with a sharp tang to it? overheated metal? rubber? sweet smell?
It smells like burning wood or leaves with a sharp tang to it.What kind of burning smell? does it smell like burning wood or leaves with a sharp tang to it? overheated metal? rubber? sweet smell?
That is probably coolant burning off the exhaust.Originally Posted by Jzza4
Check it over for coolant leaks.
