Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 52
Thread: What kind of oil should i put in my 1990 535i M30 Engine?
  1. #21
    Melbourne, Australia
    Where do you live?
    Fill in your PROFILE!!!
    Here in Australia I use Mobil 1 5W-50 in my M30.
    I'm not sure if it's available in other countries or not.
    I wouldn't use it it later higher-tech engines but I think it suits the older M30's with a few miles on them just fine.
  2. #22
    If your oil pressure light is coming on:
    1. Take the sender out and wipe it off, then put it back on. See if that helps.
    2. Replace the sender for ~$6 at BMA. See if that helps.
    3. Try thicker oil.
    Cheaper oil makes more frequent oil changes affordable, whereas synthetic oil is an expensive habit, so you'll be tempted to let it slide. If you bring them the filter, WalMart will change your oil for ~$13, viscousity of your choice, ifn you don't wanna get messy. If your oil is low but needs changing, add a quart of auto transmission fluid to top it off and run that way for a few days. The tranny fluid will flush alot of crud out of the engine, but don't run it long that way cuz you don't want that crud in suspension for very long.
  3. #23
    transmission fluid i am pretty sure is for the transmission.just a thought
  4. #24
    Honolulu
    Default Used K.Y. for years
    but recently swiched to Astrolube.
  5. #25
    O.C.
    20w50
  6. #26
    Jun 2006
    Atlanta
    Quote Originally Posted by aston_jag_tech
    20w50
    That's what I use Castrol GTX 20W50, in the green plastic bottles..
    aka "BMRSEB" - USA
  7. #27
    Wellington,New Zealand
    well i must be the odd one out.The bmw dealer here would put in castrol 5w 30 synthetic,so thats what i use.It doesnt get too cold here or too hot.I like the light weight at start up,thats when all the engine wear occurs.I run the oil for the full service interval,and always change the filter.
    Gone but not forgotten
  8. #28
    USA
    ..... thicker oil lowers oil pressure.
  9. #29
    baton rouge, loserana
    if you say so
    Quote Originally Posted by BillionPa
  10. #30
    Honolulu
    Default Hydrodynamics 101
    must have slept during that class
  1. New Guy 1990 535i
    By 535ibimmer in forum 5 Series BMW
    Last Post: 07-26-2006, 07:49 PM
  2. What is THe Best Oil For 535i 1990
    By eagle_eye2k2 in forum 5 Series BMW
    Last Post: 09-23-2005, 07:34 AM
  3. Buying a 1990 535i
    Last Post: 07-16-2004, 11:35 PM
  4. What kind of motor oil is best,,,535i
    By aton in forum 5 Series BMW
    Last Post: 07-10-2004, 10:14 AM
