oil at right level?
do a fuel pressure check, pump may be dead.
I would replace the DME and fuel pump relays first.
Have 525iT. 1993
Turns over really fast, no battery problem. Won't fire.
Wife just got back from 150 mile each way trip. No problem.
Then went to store 1 mile away. When she came out, it wouldn't start.
I drove over, and all it does is cranK very fast. Won't fire.http://www.bimmer.info/forum/images/smilies/frown.gif
Has gas.
Just had oil change before trip by "Jiffy Lube" place.
Any ideas?
Thanks.
oil at right level?
All no starts begin the same way. you need to verify both spark and fuel, then isolate that system. Check both. If you have neither, then it is something common to both, which can be any thing from a blown fuse to a bad crank sensor or even bad DME.
Check this and reply for more info
Faster than usual? Much faster?Originally Posted by Mistaknly
If so and it were the M20 engine, I'd suspect a broken cam belt. On the M50, how likely is a broken cam chain?
1997 535i V8
