Results 1 to 10 of 11
Thread: Help please, lower strut mounting bolt stuck and rounded
    Mar 2004
    Default Help please, lower strut mounting bolt stuck and rounded
    Like the title says one of my lower strut mounting bolts is stuck, and my impact wrench has rounded the bolt. Now is seems there is no getting this thing off.
    Can I have some suggestions please on how to get this bolt off. I have removed the rotor for best access but no dice.
    What is the procedure?
    PA
    Are you talking about the front or the rear?
    Mar 2004
    Sorry the front, the last one of three at the bottom of the strut, the outermost one.
    Tampa Bay, Florida, USA
    Spray with PB Blaster or AeroKroil and let it soak in;
    Beg, borrow or steal one of these or something close to it:
    http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
    Whack it vertically with a brass hammer if you can get one
    Then use the Bolt-Out.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Heat it with an acetalyne torch until the bolt head is cherry red, smack it hard right on top of the bolt head several times to free the bolt up and mushroom the bolt head. hammer a socket back on and remove with an impact.
    Get better sockets to prevent this problem inthe future
    Mar 2004
    Quote Originally Posted by MBXB
    How strong are those Bolt-Outs? Im thinking I might snap one on this bolt, it's very tight, 19m.
    Mar 2004
    Quote Originally Posted by joshua43214
    OK, I'm going to try this. I think I hit it from the wrong angle too many times.
    TY
    USA
    part # for the bolt is 07119911694
    pick up 6 new ones, and dont put em back on with an impact wrench.
    The Bolt-outs are pretty strong, they dig in deeper into the bolt head the more you torque on them. I've never had to use a torch. A heat gun has done the job. Previous installer probably used Loctite.
    Ramon
    Only problem with using a heat gun is that it is too cool. You want the intense heat of a torch so you can heat only the part you want to remove. the heat gun or propane is so cool, that the heat will travel farther since you have to aply it for a longer period of time. This can be bad when having to heat anything that can potentialy be damaged by the heat such as shocks or ball joints.
    I have seen guys melt ball joints trying to use propane to remove bolts from them on certain cars where a bolt is seized near the joint end. Acetalyne is really the best tool for heating, you can heat a bolt to cherry red only a couple of inches from a rubber part with out hurting it at all if you adjust it properly and aim it well. Same goes for heating alternator bolts, acetalyne will heat the bolt far faster than the housing can carry the heat off. When I worked on Saabs, the balljoint bolts would always be seized, and they are about 2 inches from the boot, in 4 years, I never melted a boot or blew one up.
  1. Caliper mounting bolt
    By pgrindstaff in forum 5 Series BMW
    Last Post: 03-18-2008, 08:53 PM
  2. Underbody Lower Strut Brace for the E34
    By nizmainiac in forum 5 Series BMW
    Last Post: 12-24-2007, 03:11 PM
  3. Seat back nut rounded -- how to remove?
    By blee in forum 5 Series BMW
    Last Post: 08-12-2007, 08:42 PM
  4. Removing rear shock lower bolt thing
    Last Post: 10-28-2006, 12:28 AM
  5. SOT: Upper strut mounting bolt broke on my friends car
    By Anton CH. in forum 5 Series BMW
    Last Post: 12-04-2004, 07:58 AM
