Hi Chris,Originally Posted by chris530it
I would guess that the sweet smell is coolant, most likely leaking from your heater core. If you turn off the heat does the smell go away? It is a DIY job with a bit of patience. Good time to flush your coolant system as well
Best,
Rory
