Results 1 to 3 of 3
Thread: E32/E34 ABS/ASC diagnosis via blink (light) code
    Default E32/E34 ABS/ASC diagnosis via blink (light) code
    Push brake pedal and the switch for ASC at the same time and keep it pushed down.
    Switch ignition on
    Release brake pedal and ASC switch
    ASC light starts blinking
    BC = blinking Code
    BC1 x(=times) blinking - no fault
    BC2 x blinking - EMS fault
    BC3 x blinking- Motronic fault
    BC4 x blinking - RPM sensor (sender)(ABS-Sensor) fault rear left
    BC5 x blinking - RPM sensor (ABS-Sensor) fault rear right
    BC6 x blinking - RPM sensor (ABS-Sensor) fault front right
    BC7 x blinking - RPM sensor (ABS-Sensor) fault front left
    BC8 x blinking - ABS-solenoid valve (Hydroaggregate) rear left
    BC9 x blinking - ABS-solenoid valve (Hydroaggregate) rear right
    BC10 x blinking - ABS-solenoid valve (Hydroaggregate) front right
    BC11 x blinking - ABS-solenoid valve (Hydroaggregate) front left
    BC12 x blinking - ASR-Plunger valve fault rear left
    BC13 x blinking - ASR-Plunger valve fault rear right
    BC14 x blinking - valve relais fault
    BC15 x blinking - return feed pump fault
    BC16 x blinking - storage load valve fault (in German Speicherladeventil)
    BC17 x blinking - pressure control
    BC18 x blinking - Leakage fault, for example das pressure container empty
    BC19 x blinking - pressure fault
    BC20 x blinking - influence on transmission, wiring fault
    BC21 x blinking - ABS/ASR-control units fault
    BC22 x blinking - TD-signal fault ( very often the speed signal)
    BC23 x blinking - Option pin wiring fault
    To BC 22:
    TD Signal fault
    control unit terminal 55
    ignition off
    remove plugs from ABS/ASR-control unit and Motronic-control unit on the left bank (M70)
    Check wiring from ABS/ASR-control unit terminal 55 to Motronic- control terminal 6 for broken wires, /Plus-/and ground connection to be checked.
    In case you find no fault, read fault codes from MOTRONIC unit/ECU
    In case no faults on MOTRONIC: change ABS/ARS control unit.
    Translated by me from German language instruction on 7-Forum. I have not checked it and cannot guarantee for correct translation.
    Please test at your own and your own risk.
    If anything not correct or to add, pls feel free to do so.
    USA
    holy crap that is awesome.
    did you hear the trick about holding down the ASC disable button till the light blinks to disable ASC while leaving ABS active?
    many years ago we posted this, but what is that trick with ASC disable? Does that work?
  1. Blink Code Pedal Faults- Stomp Test
    Last Post: 11-19-2008, 01:57 AM
  2. Lambda error code 1213 - Diagnosis Help Please
    By KBarcellos in forum 5 Series BMW
    Last Post: 04-19-2006, 09:44 AM
  3. E34 ABS light diagnosis
    By UK E34 in forum 5 Series BMW
    Last Post: 10-12-2004, 06:39 AM
  4. ABS Light Blink 3 times then off?
    Last Post: 10-12-2004, 12:30 AM
  5. i dont want my signals to light up only blink
    By JohnC in forum 5 Series BMW
    Last Post: 04-03-2004, 06:15 PM
