Oil Temp/Press & Water Temp Gauge Install
Someone asked me a while back for pics on this setup, and I just got a decent digital camera so I thought I'd post.
Pic #1: PO installed three gauges in the car (from left to right): Oil Pressure, Water Temperature, Oil Temperature.
Pic #2: Backside of cluster, sheet metal wrapped in vinyl, with lights for the gauges.
Pic #3: Oil temp sensor is part of the oil pan drain plug. (Don't ask why it's so dirty... I'm duly ashamed...)
Pic #4: Oil pressure sensor, located aft of the head (plastic thing in the upper corner is the underside of the coolant overflow reservoir).
Pic #5: Water temp sensor sits in the (formerly) blank hole by in the thermostat housing.
Robin
72 Chevy K10
01 E39 M5
