Results 1 to 2 of 2
Thread: Pre-load torque setting for Pinion
    Meridian, ID
    Default Pre-load torque setting for Pinion
    Anyone have any idea of what the pre-load torque setting on the pinion nut is when changing the companion flange on an E34 big case differential?
    Mike Holbrook
    Meridian, Idaho
    Albuquerque, NM
    My memory isn't the best but I believe it's 137 ft-lb. I did mine (3.91 LSD) with the max my air-hammer could put out and used Loctite 262. I know my worn out air-hammer can't make even 100 ft-lb. Better to err on the low side. No problems 2 years/11k miles later, it's still quiet & smooth.
    gale
  1. Replies: 14
    Last Post: 02-06-2007, 10:42 PM
  2. 540 guibo bolt torque setting
    By yaofeng in forum 5 Series BMW
    Last Post: 10-03-2006, 12:38 PM
  3. 540 steering box banjo bolt torque setting
    Last Post: 08-08-2006, 09:48 PM
  4. What's the torque setting for the 10mm bolts holding...
    By darren540i6 in forum 5 Series BMW
    Last Post: 07-05-2006, 11:14 PM
  5. Torque setting for upper Alternator/idler bolt?
    By MO525 in forum 5 Series BMW
    Last Post: 03-14-2004, 11:38 PM
