The oil level warning comes on in my car when the oil level is about halfway between the marks.Add 1/2 litre or so and see if that fixes the warning
Thank you very much! The inspection light came up so they will check it up!Originally Posted by Blitzkrieg Bob
M50 POWER
BUT S38B38 RULES
Gone but not forgotten
The level of the oil is exactly there, halfway between the marks! I will try that tomorrow and i will inform you!Originally Posted by Paul in NZ
M50 POWER
BUT S38B38 RULES
yep same as Pauls, right about the middle of the grooves I get the oil message.
when i removed my sensor, it was pretty gummy.
after spraying it out with brake cleaner (half a can, for about half an hour), it was much much cleaner and you could hear the little thing inside that moves again!
if you do that, make sure you get a new o-ring
