most likely the grommets on top 34 31 1 163 464 bmw # or 1221713 volvo # couple bucks a piece, drain the bottle and refill with dot 4 someone probably put in dot 3 and that's what ate the orignal grommets, usually no bleeding requiered
hey guys,
ive got a leak from the master cylinder, not quite sure if its from the bottle end or the seals itself.
anyone come across these problems? and any rebuild kits avail or prices on a new?
thanks
sweet, thanks for that mate!
will grab 2 of them tomorrow i think and sort it out..
Yea, suction out the fluid and remove the reservoir. Pull up while rocking it slightly side to side, not front to back. It will take quite a bit of effort to remove it, but it is strong.
