I checked the posts but to no avail. Here is the sitch:
Car runs fine for days to mabey 2 weeks. All of a sudden low coolent msg. I notice coolent leaking from overflow hose on occ. Hot weather cold weather, long drive short no matter. I fill up the coolent and repeat. Thermo? What gives? Any advice. Car has new rad and water pump. TKS in advance!!
PI
First off why did you change the rad and pump? Now it appears that coolant is being pushed out of the o/f tank. Could it be combustion gasses doing this? To find out get yourself a detector kit that will tell you if the coolant in you o/f tank is mixed with combustion gasses. If it is, well you may have a H/G problem.Originally Posted by piman
