Results 1 to 2 of 2
Thread: E32 750iL master cylinder upgrade
    Default E32 750iL master cylinder upgrade
    G'day everyone. I'm soon putting on some front and rear e32 750iL (german) brakes on my e34 535i. The front brakes are a 4 piston caliper design with 324x30 rotors, the rear brakes are the usual single piston design using 300x20 rotors. Is changing over to a e32 750il master cylinder easy / can it be done on my car? Will I need the larger master cylinder?
    It looks like the e32 750il master cylinder is a easy and direct swap.
    http://aaron.aussiefiverdriver.com/M...de-Install.htm
    Is this right?
    As far as I can see all RHD e34's use the same size master cylinder, while the larger master cylinder only came on a few e32's
  1. Master Cylinder Help
    Last Post: 07-04-2006, 10:20 PM
  2. master cylinder gone bad?
    By panzershreck in forum 5 Series BMW
    Last Post: 08-19-2005, 09:44 PM
  3. Leak at master cylinder....
    By Messerschmitt in forum 5 Series BMW
    Last Post: 03-20-2005, 11:50 AM
  4. Replies: 2
    Last Post: 02-24-2005, 05:24 PM
  5. 535 master cylinder
    By caster in forum 5 Series BMW
    Last Post: 10-08-2004, 07:45 AM
