grind as much rust off as you can, then use the rust converter stuff. sand it down then use tthe self etching primer. if theres divots to fill then use primer, wait for it to dry and use real fine sandpaper til its smooth.
Prep is 90% of the job when done nicely. It is a lot of work but very worth it. Ill type more later.
![Quote](images/misc/quote_icon.png)
Originally Posted by
McWatters
Thanks for the help, my rust consists of the obvious bottom door pannel sections. a wee bit round my gas door. and then a bit upfront on the painted pieces surrounding the grill headligths ect.
What is self Etching Primer???
J.McWatters
