Results 1 to 10 of 11
Thread: Headlights to be replaced - How to remove the grill
    Aug 2004
    S. Florida
    Default Headlights to be replaced - How to remove the grill
    Hi,
    I just got a pair of DEPO (HID) headlamps and need to replace them on my 95/525 (M50).
    I removed the four screws on each (left/right) side but it looks like the grill (It is a wide grill) is being held at the bottom coz i am able to slant it from the top.
    How do you get it out to be able to access the headlamps.
    What bulbs are used for city lights and how do i connect the city lights. Can i simple splice the wire and connect it to the low beams.
    Pl. help
    Steve
    theres little plastic clip type deals on the bottom you need to press down and out of the way with a slim screwdriver and then it pulls out. Careful not to scratch the bumper.
    T·O·R·O·N·T·O
    Use an inline tap and connect it to the 'parking light' line of your sidemarkers.
    So.Calif ( L.A. Beach Area)
    use the search feature...it works
    Quote Originally Posted by Qube
    where do u get an inline tap?
    Default I would advise you not to use an inline tap or scotch lock
    connector, its just asking for corrosion and bad connection problems. If its considered an important connection i would solder it and use shrink tubing on it. I see more messed up car hauler and race car trailer wiring using scotchlok and in line connectors.
    Quote Originally Posted by 1991 525i Novs
    USA
    how about... kill the side markers and wire them directly, then install euro trim!
    Skotch-locs are evil!
    Jul 2005
    North SF bay area Delta region
    Quote Originally Posted by joshua43214
    Yes they are !
    Using these are like asking for problems down the road, if you don't ruin the wires before you even get on the road.
    If you insist on a mechanical connector use some "Posi-Lock" connectors. These things rock !
    http://www.posi-lock.com/
    1991 525i M50 5 Sp.
    N.California
    Jul 2005
    New York
    what he said. get a long flathead screwdriver, and in the center of the grill there are two plastic clips that you need to put a decent amount of pressure on to remove. do a search on grill removal, there are some more tricks and probly pictures of what you need.
    You're my hero.
  1. How to remove headlights?
    By Dave M in forum 7 Series BMW
    Last Post: 03-28-2007, 05:42 AM
  2. Where can I get a grill like this?
    By Calico_NC in forum 5 Series BMW
    Last Post: 09-30-2006, 01:37 PM
  3. For anyone whom has repainted their grill/grill inserts
    By DanDombrowski in forum 5 Series BMW
    Last Post: 08-31-2006, 11:40 AM
  4. How do I remove the kidney grill?
    By Dan in NZ in forum 5 Series BMW
    Last Post: 11-12-2004, 12:46 AM
