Water tube is plugged in the cabin unit (is that the evap or the condensor...I can't recall). Bentley's should be able to locate the tube.
Hello folks,
I am trying to track down what bad part/blockage would cause water to dump all over the passenger side carpet after the A/C has been running for 45 minutes or so. I had to mop it up with 4 towels today, and I'm trying to figure what could cause this before it does more damage.
Evaporator? Condenser? Drier? Constipated tube that I can't see?
Bellevue WA
86 Porsche 951 - Track Toy
evaporator, The condensor condenses the high pressure gas coming from the compressor, it condenses it from gas to liquid..
At any rate , yes the condensate drain is plugged
Originally Posted by Jeff N.
I know at least there is one tube on the driver's side that you should be able to access by removing the small panel near your right shin(while sitting in the driver's seat). There might be a tube on the other side as well, I don't recall.
Thanks. So, basically a condensate drain is blocked.
Yep....
BMW parts professional
Previous rides:
BMW
E12 M535i (go the dogleg!)
E28 M535i (MMM M88!)
E34 535i M
MAZDA:
RX7 S-IV T04 (440 hp ATW)
RX7 S-I 13b bridge port
RX4 13b peripheral port
