Results 1 to 10 of 13
Thread: Multimeter Suggestion?
    Dec 2005
    New York
    Default Multimeter Suggestion?
    So my faithful old multimeter crapped out (funny, it seems that dropping these things then stepping on them somehow affects their operation.)
    Anyway, do any of you guys have any suggestions for replacements - make/model would be really helpful.
    1989 325iX 5spd Coupe Koni Adjustable/H&R
    1989 535i 5spd Bilstein Sports/H&R, Tri-Flo, Conforti, UUC SSK
    "If it isn't Diamondschwartz, it isn't... Dark Grey?"
    they have some half way decent digital ones at most part stores in the budget bins for 9.99, I tested one against a high dollar one I have at home and its reading correct. Just not as many options but does everything you would need automotive.
    Houston, TX
    Fluke, if you want to spend the big bucks. I find a Sears unit is perfectly usable and a lot less expensive.
    Lexington, Kentucky
    digital is the best option? Analog is hard to read for old eyes.
    Default This one goes on sale all the time at Harborfreight
    It also has a temperature probe and it seems to take abuse pretty well. I buy them in two's and the first one has held up longer than my much more expensive ones did... The fluke didn't survive a year even with the impact housing. If you check back every few days you'll find this on sale for 19.99
    Quote Originally Posted by NY535iManual
    Washington DC
    Analog is better if there are flucations in the current. Digital will never pick this up and if it does you will never know the range.
    Dec 2005
    New York
    Thanks a million for your suggestions. Bill, think I'm going to go with your suggestion, since I think these might be overkill!
    http://zone.ni.com/devzone/conceptd....&node=12675_US
    Boston & Attleboro MA
    Or if you are or join as an Inside track member, it's almost always $19.97
    I joined ITC so I didnt have to wait for some things to be on sale.
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Holland
    If U use it daily as I do, buy a Fluke, I have a Fluke 112 for 3 years now, perfect meter with backlit display which is very usefull if you are repairing a pinballmachine in a dark corner of a bar or measuring some things under the dash of an e34 for instance.
    If you only use it to measure volts, amps or resistance once in a while, buy the cheapest you can find.
    Lexington, Kentucky
    Good point. As I already have an analog version, I may get a HF digital one as bill is suggesting
  1. How to use a multimeter
    Last Post: 08-19-2008, 02:37 AM
  2. Craftsman multimeter with thermometer
    Last Post: 12-21-2006, 11:04 PM
  3. Multimeter
    Last Post: 05-14-2006, 06:22 PM
  4. Need suggestion about this car (Urgent)
    By Akhil in forum 5 Series BMW
    Last Post: 01-24-2006, 01:29 PM
