Results 1 to 4 of 4
Thread: Need help, first time working on car.
    pa
    Default Need help, first time working on car.
    I got quoted $1000 to change both front wheel hubs of my recently purchased e34 540i by a local shop! parts costs about $200 online so I guess I can justify spending some money on tools.
    According to these instructions....
    http://www.bmwe34.net/e34main/mainte...eelbearing.htm
    I need
    Floor jack, jackstands.
    46mm or 1-13/16" socket and T bar (I bought mine from Princess auto for US$5.00)
    250 lb-ft torque wrench, pliers, WD40, rubber hammer.
    Tools to remove the caliper/carrier and rotor.
    Maybe puller if the inner race is stuck
    Please make some suggestions because I'm clueless about tools. I did some research and it sounds like ac hydraulic is the choice for jacks. If someone could link me or give me parts/sku # for these tools or point me to someone who does business online that would be great... Thank you
    pa
    Help
    Aug 2005
    Toronto
    Go to Pep Boys or whatever and buy the best, biggest jack you can afford. You'll be glad you did in time.
    Any jackstands will do. Just be sure they're rated for enough weight.
    As for the other stuff, I dunno. Someone else will. Most quality tools have lifetime warranties, so I'm not sure how much it matters what brand you buy.`
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    USA
    gloves. dont touch the new hub or it will start to rust almost instantly. i got some loctite rust preventer spray and a chemical zinc coat.
    puller definately. also make sure you get the inner dust caps.
  1. Replies: 13
    Last Post: 04-12-2005, 10:52 PM
  2. ABS working again and time for a new camshaft...
    By simon-york in forum 5 Series BMW
    Last Post: 09-30-2004, 07:26 AM
  3. Replies: 57
    Last Post: 07-19-2004, 11:39 AM
  4. obc not working
    By Danny in forum 5 Series BMW
    Last Post: 05-01-2004, 04:34 AM
