Hi, the u've unplugged the connector on the idle valve, try removing the air pipe on the idle valve that connects into the inlet manifold. that should increase the rpm to 2000. also check to make connectors next to the fuel pressure regulator (the ones that connect onto the water pipe housing to the water pump)
good luck
Originally Posted by uk525ia
