Results 1 to 10 of 15
Thread: check engine light .....
    Dec 2005
    VT
    Default check engine light .....
    came on. The manual says it's emission related.
    I tried to read the code following the pedal pressing method. All I got is the "check engine" light to blink, but no code displayed. I assume the code should display next to the light?
    Thanks for any suggestions .........
    Mar 2004
    So Cal
    The check engine light blinking is the code. After initial blinks, if it blinks once/twice/once/twice, this would be code 1212, just an example. Go to www.bmwe34.net and it explains it and will give you the code definitions.
    Greg Mendoza
    Dec 2005
    VT
    well call me stupid! ... I thought it actually shows the code in numbers .... like my Dodge RAM does. Anyway the code is 1221 which is the O2 sensor #1 ... do I have 2 of them ?
    also ... I read up some more and found that in all likelihood it's just a service reminder since O2 sensors rarely go bad. If so, how can I shut off the check engine light? If the sensor were really bad the performance would suffer to the point of being noticeable, right?
    One more ... will driving the car with a bad sensor damage it?
    thanks again....
    its not a service reminder.
    reboot the computer and see if it repeats the error.
    USA
    i think the M50 has only 1, $75 part
    Dec 2005
    VT
    thanks ... how long can I drive without replacing it?
    Horse Country
    Quote Originally Posted by fsteyer
    Why don't you want to replace it? Not that it's any of my business, but it's only $75 bucks. If you can't afford to replace that, then you'll certainly run into more finacial debockles in the future. Besides, you'll get shittier fuel consumption rates with a bad sensor. Just a thought---
    Connecticut, USA
    Replace it ASAP, it's a cheapen
    1990 Islandgrun 535iM Sedan
    Dec 2005
    VT
    because I have to go on a trip Saturday (about 600 miles) and won't get the part before that. So will I be OK for that ?
    thanks
    the reboot will probably fix the error.
    thanks
  1. check engine light flickers with engine miss
  2. Check Engine Light On
    By begeta50 in forum 5 Series BMW
    Last Post: 04-03-2006, 10:40 AM
  3. check engine light
    By nuwde in forum 5 Series BMW
    Last Post: 01-12-2005, 02:00 AM
  4. check engine light came on
    By gsotis in forum 5 Series BMW
    Last Post: 10-30-2004, 11:34 AM
  5. Check Engine Light
    Last Post: 07-09-2004, 02:55 AM
