hmmm no takers
okay, yesterday crusin around when my amp quit. so i pull over look at my amp and the ground had feel out. so i fix it get into the car and trun the key usally starts in the first three revolutions, but did not.
So very convinent that i was in a autozone parking lot. check fuel pressure by pulling main hose and gas spays, okay got gas pressure. Maybe flooded pull spark plug and it is dry as can be.
when i had gotten it home i had pulled the battery, next day put the battey back turned the key and started right up. Soo happy at what had happend i got in and had a ride to my homeis house. when it's time to leave does not start. reset comperter then it statrted but on the way home after 400 meters souned like it was runnung on two cyliners.
Today perfored crankshaft position sencer and it gives me ohms for for the M20/M30 when i have a M50 in the car. is it the bently that is wrong????
hmmm no takers
Learn how to spell crackhead. And you paid too much for the last hit... just tellin you now.
thanx for the help Cool guy, your really funny
your spelling does suck!
I really dont have a straight answer for you. How is the general condition of the electrical system, like can you see and corroded connections by the battery cables and groung wiring? You could have a bad ground going to the engine itself causing an intermittant failure.
no clue man.
when i installed the new sterio system i had put in all new high performance battery terminals, bonding staps, and cables.
Maybe it's the rain??
You mean that you didnt know that E34s cant be driven in the rain?Originally Posted by Dr. evil
if the problem started after that then id guess thats where you would track the problem. sounds like a bad connection.
put the key to the run position and leave it there, and make damn sure the amp is off before you crank. also, did you use dielectric grease on the terminals?
i used the treminal grease from autozone on the battery only.
