Results 1 to 8 of 8
Thread: ...Shut engine off and "Oil Pressure Sensor" shows on my display
    Bay Area, CA
    Default ...Shut engine off and "Oil Pressure Sensor" shows on my display
    I just got my car back from the shop. The engine was replaced with a new one from bavarian auto recycling and when I turn off the car I get a message on my display of "oil pressure sensor." Have any of you had this problem before? I looked this up at bavauto.com and I can only find oil pressure switch. I am assuming this is the same thing as a sensor. Do I need to replace it? any suggestions welcome.
    Greg Mannino
    baton rouge, loserana
    id replace the switch as they get slow sometimes and don't close before the check control times out
    USA
    i just sprayed the switch out with a crap load of brake cleaner and put a new oring on it... but that may or may not work in your situation.
    Bay Area, CA
    Ya i'll just buy a new one, its only 10 bucks
    Greg Mannino
    USA
    **** thats cheap! the one for my car is over $100
    12 61 1 710 509 $10 bucks at the dealer for a 530, same sensor that's been in use since around 86 on everything
    Quote Originally Posted by BillionPa
    the hedge hog rules!
    USA
    i was too tired when i posted that, read oil level sensor for some reason O_o
  1. Message Display "Check Coolant Level" & Leakage
    By rufryder in forum 5 Series BMW
    Last Post: 01-28-2007, 01:12 PM
  2. "Trans Program"/"Limp Mode" Redline a Engine?
    By JMI in forum 5 Series BMW
    Last Post: 06-12-2006, 10:51 PM
  3. Pre Cat O2 sensors replace, still one shows "aging"
    By David Shealey in forum 7 Series BMW
    Last Post: 03-07-2006, 10:07 PM
  4. On the sevice display it reads "check control"
    By old bob in forum 5 Series BMW
    Last Post: 04-30-2005, 08:07 PM
  5. cd changer shows "err", any ideas??
    By John in Nova Scotia in forum 5 Series BMW
    Last Post: 12-25-2004, 06:49 PM
