Check the fuse in the fusebox (but if everything else works fine I guess this is not an issue), after do check the wire plug that is attached to the washer motor (it is on a good place for picking up dirt) and clean it, also it would be nice to measure is there a 12V on it when you activate the washer ... if this does not help the new motor is a cheap investment and easy to change.
Good luck.
