the numbers look a little high, you didn't oil the cylinders did you? as oil can mess up compression #s the cylinders don't really hold the pressure for very long as they don't need to, there could be some crud on the spark plug seat keeping the tester from sealing, if you are getting better then 120 outta the "bad" hole it's not going to be a dead miss, you may not even be able to notice it while the engine is running, if it's good enough to get to 180 theres no mechanical problem
