already got the booze and everything was fine, but i will try to get the barrel out tomorrow with a paper clip and get the broken pin out, do you know if theres a torque wrench setting for the steering wheel? because my understanding of it is that the steering wheel boss is made of a softer metal than the column and seeing as the column has tapered splines on it if you over- tighten it wouldn't it increase the size of the splines in the back of the wheel making it not fit securly
