If it's on absolutely flat ground, assuming it's not seized... what happens when you push down on it?
Lately I noticed that the gap between the wheel and the wheel well is higher than usual. I checked my tire pressures, gas level and everything. I though that shocks should sag with time and not rise. What gives??
The car rides fine and suspension travel seems to be normal. This appears to happen on all 4 wheels - mostly on the front two.Originally Posted by Qube
