Originally Posted by
BMW4LIFE
i have a 1993 BMW e34 525i that i had 205 65 r15 and was wondering if the wheels would fit a 1988 BMW 735i with the tire size 215 65 r15...
let me know...thanks!!!!!!!
It would physically fit due to the 5 stud fitment, whether it would be bolted on correctly with the right amount of positioning (too near the body, too near the outside) depends on the offset. ET-20 or thereabouts is good for an E34, not sure on the 7-series (but older 7- series was same as E34).
However, the fact that its a 'bigger' combination you would be altering the final drive ratio slightly, which affects the acceleration, top-end and fuel consumption. I'll leave you to work out which way round :-) hint: better acceleration=lower top end and lower fuel consumption and vice-versa - its always a trade off. The calculation is to compare the 2 overall diameters complete with wheels and tyres [15 inches - in mm plus 2X215 or 205 X65%].
Cheers.
1994 E34 530i MTech UK 137,000 Miles 45,000 on Alusil
