Results 1 to 4 of 4
Thread: 3rd gear synchro
    Yorba Linda
    Default 3rd gear synchro
    Took the '90 535 to my Indy and he tells me the 3rd gear syhcro is going and no fix other than replacing the tranny. Not what I expected to hear. Then he says a used 5 speed is about $1000, plus another $450 labor.
    Anyone has experince with replacing their 5sp gearbox, does this make sense?? Car has 133k miles, redline thruout.
    Unregistered Guest
    Why is there "no other fix"? Can't they just replace the synchro ring, a $20 part? I have done my older BMW transmissions several times, but I am not familiar with that particular unit. I don't have my service manual handy to see how complex the job is. It still won't be cheap to take apart but should be a lot less than $1500.
    Dennis
    The Getrag tranny is a press-fit type. You press the case halves together and the shafts into the bearings. Basically, if you open the case up, you need to replace all the bearings.
    Jeff
    Bellevue WA
    86 Porsche 951 - Track Toy
    Near San Francisco, CA, USA
    Default Before drastic action, suggest you chane lube from
    whatever you now use (probably MTL) to something else.- Maybe RedLine D4 ATF, or some other good tranny lube. Many people tell of fixing such marginal problems with a lube change.
    Quote Originally Posted by caster
  1. Top Gear M1 vs M3 vs M5
    By gmannino in forum 5 Series BMW
    Last Post: 10-19-2006, 10:38 PM
  2. Top Gear ...
    By robin in forum 5 Series BMW
    Last Post: 11-20-2005, 03:49 PM
  3. Top Gear
    Last Post: 10-28-2005, 01:51 AM
  4. Please help!-can't get into gear 89 535
    By amindseye2020 in forum 5 Series BMW
    Last Post: 12-31-2004, 08:34 AM
  5. 3rd gear synchro
    By caster in forum 5 Series BMW
    Last Post: 04-06-2004, 10:51 AM
