Results 1 to 9 of 9
Thread: Cam Position and Valve Adjustment
    Seattle, Wa
    Default Cam Position and Valve Adjustment
    Please settle a disagreement -
    It is not truely required for the piston to be TDC when adjusting valves, just that the rocker arm cam followers are completely off of the cam profile, correct?
    Seattle, Wa
    Anybody?
    Hockinson, Washington
    As far as i know, if the eccentrics are off of the cam profile, the valve can be adjusted. Just think about it.
    kingsbridge, devon, uk
    that is correct
    Aug 2006
    Portugal
    that's correct, as soon as the valves are free you can adjust them and you also can adjust them on several cilinders in one time
    Seattle, Wa
    Thanks all. That is what I thought.
    I just used a black marker to mark the rocker arms which had been adjusted.
    Nov 2004
    Middle England
    Quote Originally Posted by JMI
    of course !
    '90 535iSE Auto (AE+EAT) 123k miles
    '86 F288 69k miles
    '06('89)- PGE 2.0DOHC Turbo
    '03 A160LE 19k miles
    1914 Stellite E2A (no odometer!)
    (+ others I daren't mention here)
    www.pyghtle.com
    Honolulu
    Default Concentrate on the Lobes
    being in the right position 180 from the rocker, because the motor sit at a slant it can lead to mis adjustment.
  1. M20 Valve Adjustment...
    By TheEndIsNear in forum 5 Series BMW
    Last Post: 08-28-2006, 02:59 PM
  2. valve adjustment
    By kevind89e34 in forum 5 Series BMW
    Last Post: 05-25-2006, 10:07 AM
  3. valve adjustment???
    By xphilter in forum 5 Series BMW
    Last Post: 09-21-2005, 06:03 PM
  4. valve adjustment sequence
    By paschalisg in forum 5 Series BMW
    Last Post: 03-16-2005, 05:27 PM
  5. valve adjustment tool?
    By panzershreck in forum 5 Series BMW
    Last Post: 07-11-2004, 08:08 PM
