Results 1 to 10 of 10
Thread: Lock mechanism removal
    Hockinson, Washington
    Default Lock mechanism removal
    How do i remove the locking mechanism from the front passenger door?
    Honolulu
    Default sacrafice a cheap long screw driver
    and make a tool to release the door handle cover, exposing two screws or bolts, I think some of the later models got jiggy and turned things inside the door. so you'll still need to remove the interior panel.
    You can acces the release from a little access hole caovered with a black plug at the end of the door just above the latch. just heat up and bend the tip of a long thin driver into a small hook to grap the sliding release for the handle.
    If I remeber it's pull to release, and push to lock.
    A nail and vice-grips worked well enough to release the door handle cover. I removed the screw/bolt that was revealed. The locking mechanism is still held fast though.
    In this image, the two red arrows point to piece of metal that have some play between them, which i suspect is my problem.
    BTW, its push to release, pull to lock.
    What do i do next?
    Honolulu
    Default Unscrew the collar
    on the lock, and check to see if there is a screw or nut for that thing oposite the lock.
    Mine is an older model so that was a torx screw, but the newer models may have a nut inside the door.
    OK, i got that far but the window track is in the way and i dont know how to remove it.
    Jun 2006
    Sydney Oz
    Try this site:
    http://www.bmw4life.com/doorLockActuator.htm
    Worked for me - but I think I used an allen key rather than the Torx
    '90 E34 M5
    '89 E34 535i
    '74 R90S
    MB 560SEC
    '74 Jensen Interceptor
    '54++ VW Subaru Turbo hybrid
    etc
    Thats for a rear door. I have the part loose, the window track is keeping me form pulling it all the way out.
    lower/raise the window a little bit?
    Its the window track, not the window itself.
  1. Ignition Lock Removal Problem
    By bmwsed in forum 5 Series BMW
    Last Post: 01-05-2009, 02:52 AM
  2. Steering lock assembly removal and replacement
    Last Post: 08-30-2008, 03:45 PM
  3. door-lock cylinder removal and switch (?)
    By timandbim in forum 5 Series BMW
    Last Post: 12-08-2007, 12:05 PM
  4. Glovebox lock cylinder/tumbler removal
    By GoldenOne in forum 5 Series BMW
    Last Post: 09-09-2006, 11:54 PM
  5. Steering wheel lock mechanism
    By Luftpost in forum 5 Series BMW
    Last Post: 12-06-2005, 04:09 PM
