Results 1 to 7 of 7
Thread: Brake master leaking
    Default Brake master leaking
    Hi gang,
    Has anyone had problems with the booster mounted brake master cylinder leaking on a 540i? There are two lines going into the top of the cylinder and they leak when I'm parked at a slight nose-down attitude in my driveway, but not on a level street. Is there an O-ring that goes bad on these things? I couldn't find anything in my book on the subject.
    Brian
    Default They are just seals where the reservoir lines go in... they are relatively
    easy to replace.
    Quote Originally Posted by Brians540ia
    Hi gang,
    Brian
    Default Is it a dealer item? Thanks for the response!
    easy to replace.
    new540iowner Guest
    Default Ditto, I've got the same leak. I ended up using some...
    RTV Silicone on top of the two black lines to partially seal the leak. If you end up replacing the top two lines, don't you have to bleed the system of air bubbles?
    SCHUYLKILL COUNTY, PA.
    Default mine leaked after i installed a new brake booster....
    i got new ones from the dealer. no more leak.
    tim s.
    Default New seals from dealer - $5.50 apiece - new type too!
    Hi gang,
    Brian
    Don't do that... get the seal from dealer... Bleeding is easy... just hook everything back up... leave the cap off... depress the pedal a few times... like 5... but very slowly or otherwise brake fluid shoot out everywhere... and then put the cap on and you are done.
  1. OT: brake booster or master cylinder?
    Last Post: 10-14-2007, 08:38 AM
  2. Master Cylinder Seals Leaking
    By Evan in forum 5 Series BMW
    Last Post: 04-30-2007, 11:51 AM
  3. e34 master cylinder leaking
    By fuzion in forum 5 Series BMW
    Last Post: 07-10-2006, 01:45 AM
  4. How much should a brake master cyl job be?
    By Jason in forum 5 Series BMW
    Last Post: 05-12-2005, 02:35 PM
  5. Leaking master cylinder - brakes
    By Am Piobaire in forum 5 Series BMW
    Last Post: 03-21-2005, 05:59 PM
