do a DME reset to adjust to the elevation change, you could have damaged the spark plug by not having it in there properly with oil and exhaust blowby. i would replace all the plugs. the intake leaks could have caused some damage to the engine with silicon particulates, get some molybdenum disulfide oil additive to alleviate it.
