Results 1 to 5 of 5
Thread: Do speed sensors wear out and wiring question
    Hockinson, Washington
    Default Do speed sensors wear out and wiring question
    Do speed sensors wear out (in the differential)?
    and
    Where do the wires from the fuel sender go (wheres the other end of them)?
    Bump?
    Orlando, FL (Gainesville)
    pretty sure they do wear out and/or get a bit dirty...sudden acceleration while on cruise control is a common symptom...
    Nov 2004
    Gateshead,UK
    The 2 fuel tank wires end at the dash cluster.
    Cheers,
    Shaun
    baton rouge, loserana
    the diff sensor can crap out with age, it's not a ac pluse generator it's a switch, you can test it with a multimeter set like you are testing a diode -I+ or -<+ is usually the picture for the setting
  1. Replies: 0
    Last Post: 12-02-2006, 10:39 AM
  2. Replies: 6
    Last Post: 10-22-2006, 08:51 AM
  3. HID wiring question
    By jarome in forum 5 Series BMW
    Last Post: 07-08-2005, 04:44 PM
  4. Speed Sensor / Wiring Diagram question
    By LondonMike in forum 5 Series BMW
    Last Post: 01-17-2005, 11:02 AM
  5. Tyre wear question
    By Marshy in forum 5 Series BMW
    Last Post: 03-06-2004, 02:19 PM
