does the 'code' immobiliser function only work once? (as in, you set it, then, when you deacticate it, it needs setting each time you leaver the vehicle) guys
Needs you to set the pass code each time you use it.
Blog - Click here to connect to #bimmer-info chat channel
Forum Rules
