Results 1 to 4 of 4
Thread: 540 guibo bolt torque setting
    East Brunswick, New Jersey
    Default 540 guibo bolt torque setting
    Bentley makes no mention of any M14 bolts in the propeller shaft section. The only torque setting mentioned of the M14 bolt in section 26-1 propeller shaft of the torque setting book is for E31/E38/E39 for 140 N-m.
    What is the torque setting for these six bolts?
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    In absence of specific published torque value for the M14 guibo bolts. I used the general setting for M14 grade 10.9 bolt, 200 N-m.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    Default I wouldn't, i would use the numbers for the
    e31,38,39 as listed here.
    Quote Originally Posted by yaofeng
    I came across this yesterday again as I fitted the propeller shaft to the guibo. All six bolts are M14x1.5, grade 10.9. According to the general value in the book it should be tightened to 200N-m, or 148 ft-lbs. I did only 90 ft-lbs thinking they were M12 so I'll go back under again today. 140 n-m is for M14x1.5 grade 8.8 bolts.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
  1. Replies: 14
    Last Post: 02-06-2007, 10:42 PM
  2. 540 steering box banjo bolt torque setting
    By yaofeng in forum 5 Series BMW
    Last Post: 08-08-2006, 09:48 PM
  3. What's the torque setting for the 10mm bolts holding...
    By darren540i6 in forum 5 Series BMW
    Last Post: 07-05-2006, 11:14 PM
  4. Pre-load torque setting for Pinion
    By mholbrook in forum 5 Series BMW
    Last Post: 06-26-2006, 04:02 PM
  5. Torque setting for upper Alternator/idler bolt?
    By MO525 in forum 5 Series BMW
    Last Post: 03-14-2004, 11:38 PM
