Resolder the LKM, the relay inside for low beams has 2 ON outputs, one does probably not work on yours. Solder the relais, clean the contact surface of the contact of the relay. Further info here
http://www.bimmerboard.com/forums/posts/255215
anyone try the sodder trick to keep the low beams working or would you guys recommend a new or rebuilt lkm module tia
can you dissable the warning all together?
What waring? In case you have installed Xenon? Yes, possible, done in Germany, see the pics in the second posting by the German 7-Forum electronic expoert, the circle shows the change
http://www.7-forum.com/forum/showthread.html?t=52455
If you cannot see the pics, first register there on www.7-forum.com
yup I had xenons on my e32 and it threw the warning and im getting some this fryday and don't want the warning again. Thanks!!
