Results 1 to 10 of 12
Thread: BMW 520 model 1993
    Aug 2006
    Default BMW 520 model 1993
    Hi,
    My friend I have question.
    I have replace my car bmw engine with new engine
    BMW 520
    MODEL 1993
    AFTER I HAVE NEW ENGINE WITH SAME THE OLD NOW I WANT TO START
    ENGINE NOW START I OPEN PLUGS SPRING
    IT FULL OF BEZEN.
    FRIEND CAN ANY ONE TELL WHAT PROCCESS I NEED WHEN I REPLACE ENGINE
    ALL
    THX
    Sep 2006
    Overpelt Belgium
    Hi,
    Can you be more specific in what you mean?
    For a manual you can use Haynes Service and repair manual.
    regards
    Nov 2004
    Gateshead,UK
    Quote Originally Posted by salih
    I have replace my car bmw engine with new engine BMW 520 MODEL 1993
    IT FULL OF BEZEN.
    Why are you replacing the engine? Is it knocking/rattling/smoky? A lot of problems can be fixed without replacing the engine.
    HTH,
    Shaun
    Aug 2006
    Default Plz your advise
    Hi,
    My friend thx for replay.
    Yes it is bmw 6 speed 520 year 1993,
    I have replace whole engine with new engine from same model 520 year 1993,
    Question
    1-Do I need to chnage ECU engine control unit,I put old engine ECU
    2-I have with first start I found that engine pump more feul
    even the spark plug is now is wet wityh benzen.
    3-in case of replace all engine what advise you have for me to do
    thx
    Quote Originally Posted by E34-520iSE
    HTH,
    Shaun
    Derbyshire, UK
    If it's the same model year and type (M50B20) engine, you shouldn't have to.
    Is the new engine running normally, poorly, or not at all? If it's running poorly or not at all, and all the plugs are wet with fuel, I would suspect an ignition problem. Check the crank position sensor, engine grounds, etc.
    Bring it round to my place Saturday morning and I'll have a look at it.
    1997 535i V8
    Aug 2006
    Quote Originally Posted by DaveVoorhis
    HI DAVE
    your comment belwo
    my question plz what I do with " Check the crank position sensor"
    Plz tell your advise how to fix it
    Sep 2006
    Overpelt Belgium
    Not every ECU is the same as i know.My M50B25 has 3 ECU computers.
    Last numbers: 403 - 405 and 413. The 413 is for Vanos.
    Derbyshire, UK
    It's the sensor mounted above the toothed ring around the crankshaft pulley. Disconnect it and replace with a known good sensor, then try starting the car.
    I assume your car doesn't start. Right?
    It sounds like you have ignition problems. Since the engine has just been replaced, there's a lot of opportunity for disconnected, defective or mis-connected sensors, dislodged relays, cut leads, disconnected ground straps, and defective new engines. You probably need to work through the "Engine Driveability Troubleshooting" table in the Bentley book.
    1997 535i V8
    Derbyshire, UK
    Quote Originally Posted by CarloE34
    You're right. I wasn't being clear in my original message. I wrote "same model year," but I should have written "same engine." I.e., if it's the same engine and engine sensors, the ECU should work. If it's VANOS vs. non-VANOS (VANOS was introduced, I believe, with the 93 model year) then it will probably not work.
    1997 535i V8
    Norway
    What was wrong with the old engine? You could try with the sensor from the old one.
    Eurospec-12/1988-535iL-M30B35-5speed
  1. e34 S3 model on the 'bay
    By Qube in forum 5 Series BMW
    Last Post: 01-20-2008, 01:19 AM
  2. E34 1/18 scale model
    By LunatiC in forum 5 Series BMW
    Last Post: 12-31-2007, 12:52 PM
  3. Wtb: E30 89-91 Is Model
    By kyleN20 in forum 5 Series BMW
    Last Post: 11-02-2006, 04:25 PM
