I'm not sure about the E30 M3 shifter, but I am using a shifter from a Z3 and it works great.Originally Posted by L11_XTC
hi im wanting to upgrade my shifter on my 1994 525 24v to a short shift, does anyone know if the e30 m3 short shift will fit straight onto my car or of any good alternatives, i am in the uk, thanks
CraigMo's Black BMW + M50 5-speed + 3.64 LSD + Conforti Chip/NGK Plugs + Z3 SSK + Magnaflow + Koni/Eibach + 17" MMII Miglia + 245/45/HTRZ + 850 Front/540 Rear Brakes + UUC S.S. Lines + Shadowline
I'm using the Euro e36 M3 shifter & it works great. Here's an assortment of various shifters:
The missing part number is 25 11 1 222 955
You can do a part number search on www.realoem.com to find what models the various part numbers were used on.
gale
I'm using a Z8 shifter. Any BMW shifter will work as long as it has the bend in it. BMA sells a complete kit, I'm not sure what shifter they used though.
http://www.bmaparts.com/epcgetspecia...entid=bmaparts
The Z3 would give you a shortest shift, but it doesnt have the bend.
The E36 series would give the shortes shift movement, of those with the bend.
Eurospec-12/1988-535iL-M30B35-5speed
I have the E36 M3 shifter
I like it very much!
Purchased from BMA. The kit did not have everything I needed for a shift linkage overhaul, so I purchased the remaining items from a local dealer.
Didn't bend anything b/c everything cleared the guibo and shaft, but always double check to make sure nothing touches.
Support your American Flag Merchant Marine
No BMW at this time, eyeing a 91 318iS. 00 Saab 9-5, 89 Bronco XLT, 05 Kawi Z1k, 00 Ducati 748S Bip
I'm using a modified E30 short shift in my car. I cut it right down in height for comfort. The difference was unbelievable! It's been on 2 years and I can't imagine life without it - it's even shorter than the Z3 one. It's the same height as the one on the new Astra's. Just a little stubby thing poking up - so comfortable! I give it 12/10! I can post a pic tomorrow if u are interested!
Cheers,
Shaun
