Results 1 to 8 of 8
Thread: ETK Crashing - any ideas
    Nashville, TN
    Default ETK Crashing - any ideas
    I set up a freasly loaded win2k machine with ETK on it. Am getting random shut downs of the program. Was curious if anyone had similar problems and a solution.
    D.-
    Derek A.
    90 535i 5 Speed - Style 5 17"
    East Brunswick, New Jersey
    Why not use WinXP? That thing is six years old.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Derbyshire, UK
    WinXP and Win2K internals are not significantly different. If the ETK is crashing, the problem probably lies elsewhere. I've had no such problems with my copy.
    Do you use the computer for anything else? Check for random crashes in other software; if they occur, a not uncommon source of these on a fresh OS install is failing RAM or a defective CPU fan causing the CPU to overheat, though the latter usually locks up the whole computer.
    1997 535i V8
    Norway
    Start->Run-> type "eventvwr" (without the quotes) check the system and application log around the time the application crashed.
    Eurospec-12/1988-535iL-M30B35-5speed
    The Netherlands, around Amterdam (as every place is)
    Quote Originally Posted by Derek A.
    D.-
    I would check 2 things:
    - there is an ERRLOGS subdirectory in the ETK directory, see if it contains any useful error info
    - I think ETK uses an ODBC connection to the ETK database, see if your win2k machine has a correct ODBC installation.
    Good luck
    You're a victim of your brain
    did you install it in the correct order? Its very fussy like that.
    T·O·R·O·N·T·O
    If you're adamant to troubleshoot it and not attempt to reinstall the application, we can get technical and process dump ETK on crash.
    If you are, grab this an install Typical on the PC:
    http://msdl.microsoft.com/download/s...6_6.6.07.5.exe
    Then as a stopgap, go START / RUN / drwtsn32 -i
    - this will set DrWatson as the default debugger
    Run ETK, let it crash, then START / RUN / drwtsn32
    - you should see an entry in the box below for the ETK
    - double click on it and paste all the plaintext information here
    If that's no good, then we'll capture a process dump.
    That's if you want to go that route.
    Benneton (United Colors of)
    as a windows 2k user, my problem was fixed when i uninstalled and scrubbed the registry entries out. install after that, fine. windows 2000 is the only operating system that microsoft made in the past 6 years, for the person implying thatthere was an alternative.....
  1. any ideas?
    Last Post: 12-18-2008, 04:48 AM
  2. Need some ideas
    By Black 535i in forum 5 Series BMW
    Last Post: 03-07-2008, 08:25 PM
  3. need some paint ideas?
    Last Post: 05-26-2007, 12:34 AM
  4. M60 intake ideas
    By Boone.Msi in forum 5 Series BMW
    Last Post: 02-20-2007, 10:50 PM
  5. Any ideas on how to get $900 in two days?
    By Dan in NZ in forum 5 Series BMW
    Last Post: 08-14-2005, 03:26 AM
