Results 1 to 10 of 13
Thread: Billowing White Smoke
    Maryland
    Default Billowing White Smoke
    after idling for ten minutes while I cleaned my windows inside and out.........
    I drive off nice and easy in my shiny "new" E34 and a ton of white smoke billows out of the tailpipe along with the check engine light and some hesitation... after a tenth of a mile the smoke is gone but the check engine light is still on
    check engine light has flashed on and off briefly the past couple of weeks...
    Does anyone have a Peake tool they're willing to loan me for a deposit?
    T·O·R·O·N·T·O
    Quote Originally Posted by Evan
    If you were local Have we checked the usual suspects for white exhaust smoke?
    Houston, Tx
    Compression leak-down test first and foremost. Drain the oil, check the coolant.
    Maryland
    ship it to me.. i'll pay all costs and give you a $150US deposit
    as for the smoke.. why would it come on hard like i blew a gasket.. then go away?
    Benneton (United Colors of)
    are you saying that your stomp test produces non-sensical results? try disconnecting the battery for an hour and running it again. you'll lose your stored codes, but you'll see immediately what's wrong.
    Maryland
    i can't get the stomp test to give me any results...
    Honolulu
    Default might just be the
    PVC plate thing on the manifold.
    the V8s have a pvc thing on the rear of the manifold that goes, and produces symptoms like this.
    Chicago
    Don't fret yet, Evan, it's just "that time of year". I went through the same paranoia a year ago when I first had the car, minus your check engine symtoms. One 45 degree F evening I stepped out of my car after driving it a few blocks and stepped right into a large cloud of a billowing white smoke! Wow, what a scare... I thought for sure I had blown a head gasket. Thing was, the smoke was odorless and no sign of coolant at all. As the season progressed into colder temperatures, no more billowing smoke. As pointed out above, I believe this is simply a result of the large and complex exhaust system on our 540s. It probably accumulates condensation inside easily if go on short drives. Hope this is your problem and nothing more
    _
    Jul 2005
    Toronto Canada
    i have to agree with Blitzgrieg Bob
    just an idea tho.....
    it might be the cranck case ventilation and oil separator combo under and and the back of the intake... I had a E32 and it did the same thing ..pretty typical of this set up on the motor... the back plate needs to be changed do the front one as well.....here is sum pics
    #3 in this pic is the plate with the o-ring to replace
    good luck fairly easy repair tho
    dablack
    92-535
    Nov 2004
    SF Bay Area
    Default I had same symptoms on '94 530
    I had roughly the same thing happen some years ago on my '94 530iT. Just driving down the street when all hell broke loose with huge clouds of white smoke coming out the back with the car running crappy, and I thought for sure that it must be a head gasket or cracked block. I was able to drive it to my indy and come to find out it was some sticking crankcase or perhaps throttle valve or something (never quite got the story straight from the indy, but sounds like the PVC [PCV?] plate thing mentioned above). Don't panic just yet.
    Hal
    1994 530iT Nikasil powered 158,000 mi
    1999 528iT 92,000 mi
  1. White Smoke/Steam
    By Golgade in forum 5 Series BMW
    Last Post: 12-04-2008, 11:26 AM
  2. White Smoke!
    By Roderick in forum 5 Series BMW
    Last Post: 12-17-2006, 12:02 AM
  3. M20 White smoke help
    By 520Ichester in forum 5 Series BMW
    Last Post: 02-16-2006, 04:36 PM
  4. Blueish white smoke
    Last Post: 02-03-2006, 01:31 PM
  5. White Smoke
    Last Post: 12-01-2005, 03:15 PM
