Its possible the window could jam and/or burn out the motor if it got misaligned. Try adjusting the alignment, there are instructions in the Bentley E34 manual how to do that.
If thats not it you could try swapping parts with the passenger door to see which is broken.
It's probably a torx screw holding the actuator to the door.
