Thread: Exchange fuel injectors for carbs?
    Vancouver, Canada
    Default Exchange fuel injectors for carbs?
    Has anyone heard of modifying a fuel injected engine to a carburetor?
    Honolulu
    Default Why?
    everybody went from carbs to injectors.
    I certainly don't miss working on carbs
    May 2005
    Jet City
    Russ Turner on www.Ferrarichat.com has done so with his Mondial with impressive HP gains. He changed from the Bosch CIS injection to four Weber carbs (V8). Probably the only carbureted and fastest Mondial you'll ever see. Last I heard he gained about 100 HP over stock with countless fuel mapping, jetting and dyno pulls.
    I'll see if I can dig up the threads.
    Changing from programmable electronic fuel injection to carburetion would be a step backwards on a street driven car. For drag racing it would be a different story.
    You have to register to see the pictures but here are some shots of a CIS converted 3 liter Ferrari V8 to 4 Weber down draft carbs.. He is getting close to 300 HP from 3 liters at the flywheel and it's still streetable. http://snipurl.com/y1uy
    Here are some dyno figures from 2004 when he was first setting this up, showing stock output and revised/corrected. http://snipurl.com/y1vc
    Spasso
    530iT, 525 5-speed , 328is.
    Vancouver, Canada
    Thanks Spasso. Just the kind of thinking I was looking for in my research.
    May 2005
    Jet City
    Go to www.ferrarichat.com and look for all of the threads by "snj5" and you will reap all the research you can possibly use. This guy is really good.
    If you start supercharging or turbocharging then EFI is the ONLY way to do it right.
    Spasso
    Honolulu
    Default Triple Weber DCOE set up
    that would be the only real option.
    Lots of fun to jet, sync and tune.
    But they will roar when opened up.
  1. FPR/Fuel Injectors
    By nirvana19 in forum 5 Series BMW
    Last Post: 03-22-2009, 05:20 PM
  2. Anyone have any use for 6 30#/hr fuel injectors?
    Last Post: 06-06-2006, 09:26 PM
  3. 535 bosch fuel injectors -
    By Rustam in forum 5 Series BMW
    Last Post: 03-02-2006, 09:18 AM
  4. Fuel Injectors
    By Hector in forum 5 Series BMW
    Last Post: 08-03-2004, 01:45 PM
