Mileage is 239000km (guess its about 148000 miles). Currently using Mobil1 ATF Premium 220.
What oil can I use to make the gearbox less noisy? It isn't whinning, but still, in first and second gears I can hear it from inside.
VIN: GG45422
VIN: GG45422
To increase the viscosity.
or
the old used car dealer trick...sawdust
Don't wanna use any additives. Too scared
Whats sawdust?
VIN: GG45422
the blade of a saw when you cut wood.Originally Posted by t_marat
don't use it....it's an old trick used car dealers did to transmissions and rear ends to make them quite
it doesn't work in engines either.Originally Posted by Blitzkrieg Bob
Is there any grade of oil which would make the gearbox quiter?
VIN: GG45422
Already, so one option would be an ATF additive for older trannies, not a leak stop, but an oil conditoner type additve may help.Originally Posted by t_marat
molybdenum disulfide.
Redline MTL its a 75w90 - heavier than the ATF.
Derek A.
90 535i 5 Speed - Style 5 17"
