Checked the plugs are nice and tight on the back of the switches?
Stu
It's getting critical fellas I'm still trying to find a solution for my defogger. None of the buttons work. The AC the recycle or rear defogger switches don't work. All they do is flash on and then off. Anyone have any clue why these switches aren't working. I've check all fuses everyone is fine. When this problem was firsted noticed it was because the AC wasn't working. The pressure was checked and that was ok. Pleeeeease help I don't want to have to pay the dealer to fix this one.......
1991 E34 535i auto
Stu
On my 89 535i I have relays, fuses, and a couple of computer boards under the rear seat on the drivers side. I did notice that one of the boards controlled the central locking system. I don't remember if any of these controlled the switches. Did you replace the switches?
you really need a Bently manual to check things properly. If you are getting power to the fuses, check the fuse with an ohm meter incase of internal unseen damage. After you check them items time to check/swap the relays and see if that helps.
The AC has a high/low limit switch which wont allow the AC compressor to work, pretty common failure.
