Results 1 to 10 of 14
Thread: Help! Heater Hose Part Number
    Aug 2006
    SE Wisconsin
    Default Help! Heater Hose Part Number
    I sprung a leak in the heater hose that runs from the aux coolant pump to the back of the engine. I tried to look up the part number on realoem.com. It looks like I need part #3, but they do not list the BMW part number. Anyone got a clue?
    http://realoem.com/bmw/showparts.do?...14&hg=64&fg=18
    Jul 2005
    North SF bay area Delta region
    Does the hose you need have custom molded curves on it ?
    If not you could use standard straight heater hose, available from any parts store.
    You may want to replace all the heater hoses if there original hoses. Just to be safe.
    1991 525i M50 5 Sp.
    N.California
    Aug 2006
    SE Wisconsin
    Yes, it does appear to be a custom molded piece. I bought some heater hose at the auto store to try to replace, but I felt like it was going to be quite tricky to do so without crimping the hose. I'm perplexed why the part shows at realoem, but they did not identify the part number. I'll try the dealer today, and if that doesn't work, hopefully I can work it out with the straight hose I have. For a temporary fix, I cut the hose at the leak and spliced back together with a 45 degree copper elbow and hose clamps.
    Default Number 3 doesn't apply to your car,thats why its not clickable, are you
    sure its not the part that i have highlighted here?
    Aug 2006
    SE Wisconsin
    Thanks for the help. I'm not sure, but the shape of that hose looks correct. However, the diagram looks quite different from the other diagram at realoem.com as well as what I see under the hood. Here are a couple pictures - kind of hard to miss the splice, which incidently came off on my way to work:
    Aug 2006
    SE Wisconsin
    Hmmm... it appears #9 in your diagram is the same part number as #16 in the realoem diagram. From what I can figure, that part seems to be used when the Additional Water Pump is ommited. It still appears to me that #3 at realoem.com is what I need - the hose that goes from the Additional Water Pump to the Engine Inlet.
    Reading, UK
    Quote Originally Posted by DigitalRelay
    That particular hose never shows up on 530's or 540's according to them, it shows up on 525's though :
    Steeraaaange.
    Aug 2006
    SE Wisconsin
    Well, I went back to realoem.com and changed the vehicle to a 1990 525i and it lists hose #3 as part 64211384746. I'm going to go with my instinct here and order it.
    Reading, UK
    I wouldnt... hose 16 part numbers do not match, meaning 3 wont either.
    Default Theres a reason for that, in the ekm if you enter your vehicle application , it won't
    let yo click on something that your car doesn't use. Thats why 3 doesn't come up for you.
  1. Help me w/ this part number?
    Last Post: 09-20-2007, 07:21 AM
  2. Help with part number
    By dolfan13 in forum 5 Series BMW
    Last Post: 12-03-2006, 09:45 PM
  3. Part Number Help
    By ChrisC in forum 5 Series BMW
    Last Post: 05-02-2006, 02:57 PM
  4. Part number please...
    By Messerschmitt in forum 5 Series BMW
    Last Post: 02-15-2004, 05:38 PM
