No info on your vehicle is indicated.Originally Posted by Ova
Also no profile was filled out.
Did you read "NEWBIES, Must Read !!" thread ?
Hi guys,
This have to be so easy but I need some kind of help.
ANyone can post any pic to see where are the needles to make the headight adjustment?
I couldn't find out in bentley or haynes. The show's only the procees but the headlight description.
Thanks in advance
Regards
1991 525i M50 5 Sp.
N.California
Absolutlely not.Originally Posted by Chris'91'525i
But I did it after read your post. thanks for reminder.
Same car here
There are clips around the lights like so...
These are the adjustable ones. This is from the right headlight.
The yellow circle represents the left/right adjuster that you turn via a white poll behind the light.
Orange and green adjust the height of the high and low beam. These are accessible through little holes in the the headlight grill (from the front of the car).
Red adjusts the left/right of the high beam and is found the same way.
I wrote that pretty bad, if you need more pics pm me.
Excelent!
Thanks!
