Ok..here's the deal
I replaced the H1 55w bulbs of my headlight with a h1 100 w.
Everything seems fine until I start the engine.
Now, the lights seems ok but the OBC says "Plate light", "1 Brake light",
"position light" and the problem is that all that light are OK.!
What could be wrong?
Regards
id check all of the fuses if that pans out throw the 55s back in and see if the problem is still there, 100 watt conversions are not always a good thing with the stock harness, these are usually done with relays to take the load, hopefully you didn't smoke the harness somewhere
